Dear Sir, Are you suffering with car alarm problem when install HID kits?
HSUN HID kits make u have no problem, we supply several Can-bus HID standard and slim ballast to solve this problem for you.
Our ballast defective rate is less than 1%, bulb defective rate is less than 0.1%
And if there is any defective product, you do not need to send it back to us
Just send me photo, then we ship the new ones to u .More information, please visit our website:
www.ledlightsfor.com Attached the photo for your reference
Why Choose CanBus Ballast ?CanBus Ballast gets rid of the flickering issues or headlamp error light issue. This issue is known on most European cars (BMW/BENZ/AUDI/VW) and now it is occur on some American cars (CHRYSLER/DODGE/JEEP).
The reason behind this is due to halogen bulb being 55W and HID being 35W. Therefore, when an HID kit is installed into the vehicle, the car ECU detects the lights are running at 35W instead of the normal 55W. Two things will happen, when it detect this. 1. When running at 35W, the ECU thinks the light bulb on one side is broken and cut down on the power it sends to the headlight, causing the HID to flicker because there is not enough power. 2. It will cause a headlight error light on the dash because it think 1 side of the headlight is broken. One or both of these issues will occur.
How does Canbus Ballast work ?This CanBus will trick the ECU into thinking the HID is running at 55W, when it is really running at 35W. This will trick the ECU into thinking that both side of the headlights are working fine and will allow the ECU to give the headlights full power to run properly, which will get rid of the flickering issue and error light issue. This Ballast is safe and will not damage any ECU or electrical wiring.
Special Bulbs with really good price like H15, 5202(H16) ,D1C/S/R,D3C/S/R,D4C/S/R, Green ,Purple, Pink, Blue ,Yellow colors are all available!!!Best regards.
Yours sincerely, Beck
HAISUN LIGHTING TECHNOLOGY CO.,LTD
TEL: +0086-020-3787-1276
MSN:sale2@ledlightsfor.comSkype : haisunled Yahoo:led.haisun@yahoo.com
WEB : http://www.ledlightsfor.com
