BMW F800GS Installation
Started by GunZenBomZ, October 04, 2009, 09:20:49 AM
GunZenBomZ
Mind you people don't take this as a set-in-stone type of install as it's a bit mickey-mouse currently.
I've sliced into the side-light power. Adding my new LED Side-light (a must once seen in person, against standard bulb.
I drilled out a small hole for a 2mm gromit & fed wire out.
I've added one pair of blue-led's under my bottom radiator fairing, simple small tight hole, activate fixing method. Couple of zip-ties or 20 later & it's done.
I've made the error of not double checking were i'd be exiting through my hand-guards for white led's. I've placed them inside of 20mm grommits again semi-fixing them till i decide on a better method.
Really love the installation you've done here... stands out very well and the White Bullets out wide will get the width of your bike seen
Many many thanks :)
GunZenBomZ
Cheers, got few more pictures.
View of hand-guard.
Other-side
Quick view from below
Ahh I understand the 'gromit' use now, neat idea to get a flush finish on the handguards.
Thanks
