cree running light stays on dimly
Started by strommer, May 28, 2012, 07:53:54 PM
strommer
Good Day,
One of the running lights on my wife's SV650 remains dimly lit after turning off.  It's possible to unplug the light.   This is a replacement set that replaced the earlier lights (failed) without a controller, and is likely the very early controller.  The install instructions were different from the instructions on the more current set I installed on my Vstrom if I recall.
Any thoughts.
Hi and sorry to hear about you issue. I've not heard of this before and the v2 Cree lights are very reliable.
If you could drop me an email to sales@bikevis.com I'll get a new controller out to you.... I think this will cure the problem.
(before mailing if you could disconnect the brown, blue and white wires if they are connected as they are rarely used or needed)
strommer
Hi Dan,
New controller arrived, installed and all is well.
Thanks for your excellent support.  If there was a picture of "outstanding support" in the dictionary, it would be a picture of you.
Thanks again
John Saunders
Fantastic John, and you are very welcome. Any problems or needs in the future just yell... we are always here to help
