What is the light beam angle on the Cree V3 Lights?
Started by bobbymacd, October 10, 2013, 03:20:29 PM
Hi Bob
They are 60 degrees, they are available in 10 degree spot format with out BikeVis Aux Lights.
bobbymacd
Thanks - so I assume that 60 degrees is better for "being seen" (especially during the day) while 10 degrees is better for seeing down the road at night?  I am more interested in the former....
Yes that's right, with the wide angle in the daytime cars in side roads can clearly see you. The narrow angle throw light long range up the road, though are less visible when not viewed from directly in front.
Both types will double the light output from a single headlight motorcycle.
