14/04/2022 - Summer is almost here!
Main Menu
Intermittantly working bullet
Started by Windy56, January 12, 2013, 11:12:42 AM
Windy56
I've recently fitted a pair of front facing white bullets with modulator on my old Pan and very good they are too. My only problem is that after half an hour into a journey, sometimes less, one of the bullets stops working. I can get it started again with a sharp tap with a hammer .. .sometimes. It takes perseverance but it usually does start up eventually but then will go off again a while later. I've checked the wiring and don't believe it to be at fault so wondered if the connections in the bullet or the LED itself could be faulty. Sometimes it does come on but only glows, rather than being lit at its normal brightness.
Have you heard of any similar reports and do you have any suggestions?
Sorry this does sound like a connection fault within the bullet.
If you could email your postal address to sales@bikevis.com ill get a complete new kit out Monday for you, no need to return anything.
Kind regards
Dan
