Vespa GTS250ie Installation
Started by Fluke, December 15, 2009, 07:39:39 AM
Jesse has made a great guide of his Bullet install on his Vespa GTS250ie.
I installed a set of Bikevis LED lights today the project was easy on a scale 1-10 its a 3. I picked a easy location to drill a hole just incase I change my mind, I tend to do that., I ran the wire to the rear tail light for power.
a few things you'll need
LED Kit from
https://www.bikevis.com/
16g wire
tie wraps
posi-taps use this instead of the blue ones in pictures
screw driver
wire cutters
meter to test I used yellow and black wire.
drill and bit size up to you
Its easy to drill hole but I'm not sure if thats the best location for the lights (note from Dan to others, you don't have to mount Bullets on outside of fairing and most people tuck them up underneath bodywork so hole never present should Bullets be removed)
I ran the wire along the cowel to the rear light
Use posi-taps to avoid connection problems with wire. the LED lights are .5v. I think 1v would have been a better choice for a LED also I think I placed
the light to far back on the scooter to be useful in daytime hours
