BMW K100LT Installaltion
Started by Fluke, July 09, 2009, 07:41:20 AM
This guide was kindly sent in by Tony Walker. He commented the install only took 40mins and was actually faster than writing this guide.
1. My bike - BMW K100 LT
2. Access to the running light was via the left carrying pod.
3. The pod was removed.
4. The LED's will be fitted on the lower front fairing; there are already pre-drilled holes here.
5. The running light fitting is in the front of the fairing above the front lamp.
6. Using a 12 Volt tester to check which wire was the positive feed.
7. The white wire is the positive or live feed on my bike.
8. No soldering iron available, so I used the click connectors after stripping back about 1" of the black outer sheath.
9. After cleaning and peeling away the plastic cover I offered the LED's up to the fairing.
10. Before, running light, no Bullets fitted.
11. After, Bullets fitted.
12.Bullets showing in low light under headlight.
